Electrical Pairing down factory wiring harness
Crimps over an insulating sleeve or heat shrink can be done fast and conveniently. But they are less than ideal. For the ultimate in reliability (pull, vibration resistance and conductivity), you can’t beat the open barrel crimp type. These are tricky to crimp correctly and not as easy to get, and is the OEM industry standard. They definitely don’t need any soldering and in fact are better than soldered joints, and also grip the insulation. Of course, this is debatable and you can use what you are confortable with. But I thought sharing this might be useful for the looks and quality obsessed.
I believe the ones I have are the barrel type. I had to get a new crimper just to use these
There is the open and closed barrel crimp. You can do a search and find out. This is actually a great topic to go through. Check it out.
I will
As you said this assumes a good crimp, so don't do what I did and buy a cheap crimper tool. I need to buy a good one because my crimps suck right now.
Sent from my SM-G781U using Tapatalk
Here’s a bit more to consider for this subject.
If you crimp, don’t solder. If you solder, don’t crimp. Terminals can be had in solder or crimp style. Of course, the crimp style is more practical and readily available. And if you want to take your terminal solder joints to the next level, use a resistance soldering station, not an iron. Again, this is for those that are obsessed with the high end of quality.
Brakes 10 or 11
