PCV Connection Questions
Dolamite
Michigan's Upper Peninsula
1980 Jeep CJ5
258 I6
3.54 gears
AMC 20 Rear Diff (1 piece Axles w/Lokka)
Dana 30 Front Diff w/Lokka
Tremec T-176 4 speed Trans
Dana 300 transfer Case w/Twinstick
Your PVC looks to be hooked up right the one in the back was a hose that ran to the air filter they probably pluged it when they went to a aftermarket air cleaner.
Thank you mtnwhlr. So you think I should just leave it as it is? The port of the PCV that is open doesn't need to be connected to anything?
Appreciate your input!
The hose from the PVC should be hooked to the port at the base of the carb.
Dolamite, I would suggest installing a breather at the rear hole in the valve cover. This helps relieve the crankcase pressure from an old engine.
Adding a breather would probably prevent the dipstick from popping out and leaking oil, wouldn't it? Any downsides to a breather?
The biggest downside would be if you have to go in for emissions testing. Excessive blow by should get filtered out so deposits won't collect on your firewall. It pretty apparent that you have a lot of pressure in your CJs crankcase if you can blow out a dipstick.
Got it. Thanks Torxhead!
    Best for votes
    on specific items
