PCV Connection Questions
Dolamite
- Media
- 9
- Michigan's Upper Peninsula
- 1980 Jeep CJ5
258 I6
3.54 gears
AMC 20 Rear Diff (1 piece Axles w/Lokka)
Dana 30 Front Diff w/Lokka
Tremec T-176 4 speed Trans
Dana 300 transfer Case w/Twinstick
My CJ5 has a AMC 258 i6 / 4.2l with a 2-barrel Weber carb. I have no complaints about how the engine runs, but I noticed the PO only has one of the ports from the PCV connected to anything. The other port is left open.
Question #1: What should I connect the open port (circled in blue on the attached picture) of the PCV to?
Question #2: Should I install a breather on the rear opening in the valve cover (circled in red)? It currently has a rubber plug installed.
As I've stated earlier, everything runs great. I just don't want to cause any damage to the engine.
Thanks for the help!
