Please help!! Vacuum leak issue
james334
texas city
CJ7 304 v8
If you have a bad gasket there, you could go to the auto parts and buy some gasket material to make your own gasket.
The two holes are for choke heater tubes that have long broken off.
No longer needed for your setup.
Seal it as Torx mentioned or loop one piece of metal tube in both holes.
UPDATE: Well the bold broke off in the block and its claimed the lives of 2 EZ-outs. I've seen some things of a choke heater plate, so I'll be looking into that soon!
I would get the other bolt out, take it off and weld the holes shut. If you cant weld them shut, you can tap them and put short bolts in with RTV on them. If you can't tap them, just fill them with RTV. Then RTV the cover back on. If you put the one bolt in, you should be fine. It will be sealed and the RTV will hold it in place on the other side. It does not take any forces. Also, if you hook up a ground and a ignition hot to the choke on the carb, the choke should work, and it will run better when you start it cold.
Unless you "want" a new intake for some reason, just seal this thing off with whatever you can. If you can seal it you're done.
$45.00
  22.5%
