Brakes Power Brake Vacuum Line?
Genaz
Silver Supporter
Featured
Easley, SC
1979 CJ7. 258cu 6cyl. T5 tranny/Dana 300 transfer case (both from '82 Scramber)
Did your post here not work?
2100 is a fairly simple swap. However the one I posted about should be a direct drop in
Having a hard time finding that EGR block off plate.
Yeah, I Googled and also tried the website on the picture you sent me. That one just redirects me to ebay but the page is no longer active. I saw the one you sent me (thanks!) but didn't really want to spend that much on a cover plate. So, I'll make something if I have to. Thanks again for the help!
YW I bought mine almost 20 years ago I want to say it was 15-20 bucks but I guess inflation.
Hi, I finally got back to this power brake project. I made my own EGR cover plate and pulled that connector you circled and got a connector that will hook a 3/8" hose to the power booster. But what about the vacuum port on the bottom of the carburetor that it was hooked to in the picture. Can I just block that off?
If it is unused it should be capped.
Thanks everyone for the help. Power brakes are installed on the CJ and it stops on a dime.
Any recommendations on an air cleaner? The old one won't fit now with the power booster and new master cylinder in the way.
Just about any small aftermarket air cleaner will work. Our member @hole just put a TJ factory system on his CJ. How about this?
K&N makes a great reusable filter.
Share with us your accomplishment by posting photos please.
Thanks for the quick feedback. Yeah, I see a lot of small air cleaner options. I was wondering about the PCV valve and the breather element. No where to hook those up that I see on any of these. Can they just be capped off, or hooked somewhere else?
$45.00
  22.5%
