Problems with ???
diver49
Problems with Jeep not running
I have a 1985 CJ7 I6 3 years in to resto. I did a engine over haul, Nutter By pass, Team rush and upgraded to mc2100 carb. I also removed the computer under the glove box and all the wiring.The problem it starts fine idle fine BUT when I give it some gas say up to 1800 RPMs it falls on its face and sometimes backfires thur the carb. BUT if I leave the vacuum unhooked from the dist. I can run the RPMs on up. I have replaced the disturbutor, checked the timing again and again even took the timing cover off and verified my timing set was on right. I have replaced the power valve checked the flot leavel. With the idle adjustment screws set 2 to 1 1/2 turns out it is lean and will get hot idleing. COULD I have some kind of elec. problem like the control module, the wiring for the nutter bypass. plugs???? One other note I believe I put Bosch plugs in I did read that could be bad. All team rush parts came from NAPA.
