Propane Conversion Tech Write-Up
CJim7
Crazy Sr. Respected Jeeper
Twin Falls ID
'84 CJ7 - 430hp 401 on propane - T18a/D300 twinsticked, Superior axles, Lockers, full boatsides, Warn 8274, OBA, 36" TSL's.
Way cool!!!:notworthy: This maybe off the subject but my grandpa bought a d14 allis chalmer tractor in the early 60's one of two that where made from the factory with lp. He used it for the main tractor for as long as they had the farm and I'd hate to think how many hours are on that motor, best part is my father bought it from the grandpa in the early 80"s and we still have it. We also have a John deere 60 with lp and have taken it to several tractor pulls and have beat several suped up 60's gas and out pulled and out powered them they even went as far as to take the hood off and check the motor for iligeale upgrades. But of course they didn't find anything but a plane stock lp motor. The lp is like a fuel injection in that the fuel is under alot of pressure and the fuel and air mixture I think are forced into the pistion better then any carb could. At least that is what my grandpa told us. Tell me if I'm woung. But on tractors I know from experinance they are power houses and the motor oil when you change it out is just as clean as when you put it in. So way cool write up.:notworthy:
I dont know what the compression ratio is on a tractor engine, but I bet it's pretty high and that would create maximum efficiency for propane combustion.
LP, when converted to vapor is far more atomized then gasoline/air through a carburetor. That fact alone means better proficiency in the combustion chamber.
Diesel engines with a propane injection are absolute monsters. The propane burn-off is quick and the high compression inherent to diesel engines is ideal.
CJim7 Thanks for the info.
You say stay away from the dual fuel setups. I ran dual fuel for a few years(late 70's gas crunch) in a 77 chevy pick-up with good results. It didn't seem to hurt the gas mpg. or performance.
I've never ran a stand alone lpg though so I don't know how well it should run on propane, but it ran as good as it did on gas, and better than a carb off raod.
I'm not pushing dual fuel, just saying I was happy with mine.
Very cool write up. A have a couple questions if you don't mind.
How far will those two tanks get you? Also, do you know if it will pass emissions?
How many miles are you running on your oil? ive heard of guys putting twice the amount of miles on thier oil before changing.
Also where do you get your bottle filled?
Im still changing oil every 3000 miles. Even though the carbon isn't there, oil viscosity still breaks down. Im just not sure when yet ;)
There are a handful of places around here that fill my tanks....so far V1 has been the cheapest. I pay $2.20/gallon with them. Uhaul is expensive at over $3 and Conoco is right up there with Uhaul.
my conversion kit has been sitting in the spare room for 2 years
guess I might now get to putting it on
great post
great post
It's a terrific upgrade. Absolutely the best modification you can do to a carbed engine...other then fuel injection. But simplicity plays a major role in this vs. standard FI.
Can you take some pictures of where your bottles are mounted?
Sure thing. Give me a few days, gf's daughter is using the digital for a school project and is highly possessive of it at the moment :D
But in the meantime...I mounted the brackets to the floor where the back seat was. Of course I had to drill new holes...I have them running front to back with the valves at the back for easy access.
Here in sac, the u-haul usually gives a discount for "highway usage" But here it is still not that cheap :cool:
~ JR
Where to fill? I'm no expert... but I may help you with questions to ask. I'm considering coverting, and filling it where they fill BBQ grill bottles is more expensive. I am told told you can get a tank like you would use for heating your home and if it is located above the tank you are filling, you can do it without a pump (gravity fill). Home propane will be cheaper. Locally for me, home fuel is $1.80 and vehicle/BBQ fuel is $2.25. Unleaded is $3.50.
Can anyone weigh in on this that knows more than me?
"Gravity fill" or "pump" fills are options. I'm not sure of your local laws regarding it, but you should always use caution and check out your local laws and so on and so forth...
Here's a link I found for you. I have a propane truck, and have always wondered what i would do if I ran out of propane while driving (usually i never get that low... but every once in a while i have thought "this might be the time...")
Filling your own propane tanks from a bulk tank... - WeldingWeb™ - Welding forum for pros and enthusiasts
That was just the first link from google search of "gravity fill propane" you can probably google fill your own propane etc for better / more info.
~ Jr
I haven't researched this yet.....but I would like to have a fixed propane tank to fill from. What Im not sure on is laws concerning the transfer of propane/natural gas from one tank to another. I know you need a license to fill propane, and home-use tanks are directly plumbed to the facility taking that liability out of the hands of the homeowner.
I asked my local V1 guy why they don't just make it self-serve at the big tank and he almost had a stroke, said it would require everyone to be licensed to transfer gaseous fuels.
I haven't looked into the regs on all this.....
CJim7 is 100% correct! But I'd like to add a few things. The good & bad.
My first conversion was on a new '63 GMC pickup. I used the dual fuel setup which will run on gasoline or propane and is switchable from the cab while driving.
The good...
Obviously propane burns clean so there are no emissions or testing. The sparkplugs never foul and the oil stays sparkling clean which greatly reduces engine wear. I had well over half a million miles on that truck before trading it and the engine was like new. That was back in the day where we were lucky to get 100,000 miles out of an engine.
I had an 80 gallon tank mounted in the bed & could drive forever between fill-ups
It's way safer than gasoline! It's pretty difficult to rupture a propane tank Vs a gasoline tank.
The best is that without stabilizers, today's gasoline is only good for up to 3 months. Propane can sit indefinitely. It also doesn't collect moisture. You will never buy a tankful of water at the gas station.
The bad...
With a propane only setup, if you let yourself run out of gas you are in trouble. You can't just fill up a gas can & be on your way.
Radiator coolant heats the regulator, if your coolant is low, the regulator freezes and you stop.
The octane rating of propane is lower than gasoline, more so back in the '60s so there is a slight loss in power and milage. But propane usually costs less than gasoline so it's still better.
$125.00
  62.5%
