Provide some input please...
Your Advice Is Appreciated...
My Jeep:
1983 CJ7
Wide Track with AMC20 rear Dana 30 Front
T-5 /Dana 300
4 inches of suspension lift
2.5 body lift.
33 inch tires
Daily Driver with light to moderate occasional trail use.
Checking charts using 33's I should be geared at 4.10. I am currently much higher then this. 2.73.
I have torn the jeep down to the frame in order to weld in a new cross member and coat with por15.....
Since I have the jeep down this far I am looking at the axles. I want to replace them.
I have found this for sale in my area..
Dana 35
When I emailed the owner of this fabrication place, he mentioned it was geared at 4.10 and that he also has a dana 35 rear off a tj which he can gear to 4.10 for me, with an auburn electric diff lock. I asked him if he could make this work for my CJ7 , he said that he could. $750 Canadian all work and taxes included.
Question is this.....Can this swap be done? if so, should I be looking at changing my drive shaft? Transmission or Transfer Case ?
I am aware of pinion angle and mounting perch changes, that is not an issue, but its the other things that I am not aware of. I am new to jeeps. If I change to these axles am I looking at completely gutting and replacing what I currently have (which is in good working order, recently rebuilt) for no reason. Another option is that he can re-gear my current AMC20 for $400.
Opinions? guidance?
Thanks for your input.
			My Jeep:
1983 CJ7
T-5 /Dana 300
2.5 body lift.
33 inch tires
Dana 35
Opinions? guidance?
		 that i wont" and a stock jeep can often handle all the driving they do so essentially they kinda blew $ (which some people like to do)
