Quadratrac
Quadratrac
That one is a little different from mine:
Here is how the vacuum lines run:
Hope this helps. Don't forget to check the chain. Here is an example:
http://www.jeep-cj.com/forums/f2/driveline-popping-binding-sound-video-26982/
Thank you so much for this diagram. I also have an auto '79 CJ7 with the QuadraTrac .
I need to replace the blower motor resistor, of which the top screw is blocked by the glove box. The glove box through which the emergency switch is mounted. According to the diagram I just need to remove the lock screw in the knob and pull the knob and lock nut & washer, correct? I'm not a pro and I don't want to eff up my jeep.
Yes, you can remove the nut and pull the vacuum switch out of the back. Double check the softness of the rubber vacuum line. If it is stiff and brittle, you may need to replace it.
