Remove Mechanic fuel pump
Master7
- Media
- 4
- Lucca Italy
- CJ-7 Ex Golden Eagle, now is miscellaneous version personalized.
AMC 304 V8 4 Speed.
Boys I must remove the pump of the gasoline and to put the plaquette to cover the hole, (I have climbed on an electric pomp) since initially I had left her in-line but unfortunately after a trip in highway she has burnt me that electric to cause really of the mechanics that when a po pushes she doesn't succeed in sending anymore the gasoline sufficente provoking a narrowing, therefore I wanted to know if to remove the mechanical pump to work more easily is better to raise the pump of the power steering or the same can be removed. AMC 304
Thanks!
Master7
Thanks!
Master7
