removing the roll bar
IOPort51
Featured
Garland Texas
1977 cj-5
2006 Toyota Tacoma
I have never removed the roll bar on my CJ5 , never had reason. but as I was looking at it this evening it does not look like you can just unbolt and lift. Is there any trick to it or does it just look like it is "built in"??:cool:
ive taken mine out a couple of times, but i have a glass tub. i have to squeeze it together with ratchet straps to get it to fit out.
Dont know for sure on a 77 but my 82 just unbolts and lifts out. You just need torx bits. Infact if you havent dont so in several years I would recommend everyone removing it because moisture can get under the mounts and cause really bad rust. Better to catch it early.
I have never removed the roll bar on my CJ5, never had reason. but as I was looking at it this evening it does not look like you can just unbolt and lift. Is there any trick to it or does it just look like it is "built in"??:cool:
Unbolt everything and remove the spacers on the sides between tub and bar, leave one side in place and "spring" the bar together and lift out the one side past the tub. 2 people makes it easier but it does come out with a little effort, the fun starts when you put it back in and have to get those spacers back behind the tub.
Why does there always have to be a "fun" part??:cool:
Yours aren't in anymore or maybe you have a glass tub and was not drilled for the side bolts? The spacers are between the body and side flange of bar.
$45.00
  22.5%
