Replacing spark plugs and wires
Another thing you can try-
Warm the engine up. Spray the SP wires with very soapy water, and see how the engine reacts.
If it starts run'n 'ruff'-Wires are arc'n to the block(gnd).
Best of luck,
If you are not sure how old your wires are, it would be a good idea to replace them. Autolite plugs seem to work the best for the ignition system in the CJ. MSD makes the best wires but are quite expensive. If you still have the oem ignition swapping out for a Motorcraft or HEI would be a good bet.
Taylor spiro-pro wires would be another good set of plug wires.I get them from summit.Agree on Autolite plugs:) mike
TORX, i think he is working on a friends Dauntless Buick 225 V6 225 V6( motorcraft???)
Also would not recommend HEI over Pertronix for the V6
