Electrical Reverse Light Switch Question
MJkid67
Featured
9
Walpole, MA
1985 CJ7, 4.2L, T5
This is my second post as I am working through some minor issues on the new to me 1985 CJ7 .
I'm having trouble with getting the reverse lights working. I removed the reverse light switch from the driver's side of the T-5 Transmission and it did not pass the continuity test when I pressed the ball side of the switch in. So, I purchased a new one from Crown, tested it for continuity before I installed it, and after it was installed (about 2 weeks ago) and it had continuity.
So I had some time this past weekend and still couldn't get the reverse lights working. I backtracked and tested the new switch with the transmission in reverse and now I don't have continuity (between the two posts). I tried loosening it a little and then tightening it a bit more than it was with no luck. I then took it out and it tests fine outside of the truck.
I'm stumped! Any ideas or tricks?
Sounds like maybe it is a NC switch and when you install it, it is making the switch during install and opening. So, if there is something in the installation that is keeping it pressed in, it will stay in that state. Is it doing this no matter what gear it's in?
Sawjaws, I wasn't aware that NC and a NO switches were available. I know that when the ball is depressed I have continuity across the two posts.
I will check later today if the state changes in other gears. Thanks.
Fingers crossed!. I did a little online research last night too and it is possible to have the switch seated too far in as well. Something thing to be conscious of as well. Good luck! 😁
Think I have the NO on my T-176 .
So I put the Transmission into first gear and checked for continuity and nothing.
I'll experiment with the depth of the switch tomorrow and get back here with the results.
Now I just reread those instructions. I'll look more closely at the washer thickness on the new switch and report back.
Yes, this switch is a NO (normally open) switch and pushing the plunger closes the switch/circuit to send power to the backup lights. This switch can also be used as a neutral safety switch, allowing power to the starter only when the tranny is in neutral or park (for auto tranny applications). When installed in the T-5 , the shift rail has a portion that pushes against the plunger to close the switch. If that is not happening, either the switch is not mounted (inserted) into the tranny far enough (due to a washer or spacer on the switch) or the shift rail is worn where it hits the plunger. So obviously test the switch when not installed using a multimeter to check continuity (none when just sitting and continuity when pressing the plunger). If the switch is good, look into the mounting hole on the tranny with a light and watch for the shift rail as the tranny is moved into and out of reverse, checking for excessive wear or not. If that all looks good, adjust the amount of shims (washers) when mounting the switch. If it is not inserted far enough (too much shimming), then the shift rail won't press the plunger enough. If it is not shimmed enough (too few or no washers at all on the switch) then the shift rail will hit too hard, possibly not able to shift into reverse or cause too much wear on the rail due to excessive pressure and rubbing on the switch plunger. My approach has been to shift the tranny into reverse with the switch removed, then start mounting the switch (screwing it in) with the multimeter attached checking continuity as I do that. Then I can tell the exact moment (how far it is screwed in) at the point the multimeter shows it is activated. Based on that distance (how many threads are left that aren't screwed in yet) I can select the correct thickness of shims/washers I need. Just in enough to activate, but not too far in to affect shifting or cause excessive rubbing/wear over time.
Nice write up TSB8C as always. I’ve a question for you. I don’t have a part # for mine on a T-176 . Last time I went to the part store i believe I got an NC and not a NO switch. Is there a description in a part number that designates if it is one or the other ? Or just take my multimeter and test it there ? The counter people had no clue there was a difference.
Great explanation ! Thanks.
Thanks for suggesting that process TSB8C.
I was able to confirm that the shift rail is present when the Transmission is in Reverse.
The rail is not present while not in Reverse.
However, with the switch fully seated, I suspect that the ball is not being depressed enough. It seems like the shaft needs to go into the transmission another 1/8" or so.
Is there a switch that is at least 1/8" longer? Could I get a used OEM or a switch from a different model that might be longer?
Perhaps there is just a little too much slop in there because of age?
Just for Schmidt and Giggles,
Stick a Phillips screw driver tip into the hole, have a sharpie ready, have a Sexy and Beautiful Volunteer shift it in and out of reverse and "Feel" how much the screw driver moves. Then do it again and mark the screw driver for the In and out positions.
Compare to your switch.
AND???
Did the reverse lights WORK before?
Do you have a Neutral Safety Switch on this Transmission ?
Pull it out. Check IT'S size. Put it in the Reverse hole and see if it works.
Go get another Neutral safely switch.
Feex't
Laughing at that post Jeep Soup!
Didn't know that there was a neutral safety switch. I'll look and report back.
Update (for those that care):
I cut down the face of the nut, but that was such an imperfect process that it weakened the extended shaft and it snapped off while I was carefully tightening it. Not sure if it's possible to do this successfully with a dremel tool.
So I found a Ford/Volvo switch that has a longer shaft (not sure about the thread diameter) on eBay. It was only $9.95, so it's worth a shot.
And, today, I found an OEM switch NOS (still in sealed factory bag) on eBay. I'm hoping that the Crown switch is not made to the same spec as OEM. I know that the Crown pinion seal is not the same size as OEM.
Evidently there is not a Neutral Safety Switch for you to check out for size. Most went to a Clutch Pedal Safe Switch.
Some had a 4-5th gear switch for the ECM unit.
Good luck, I was wondering how things were going?
$45.00
  22.5%
