Sensor on Trans and Plugs in T/C
Colo Dean
Greeley Co
74 CJ5 258 I-6, 4 spd T-18, Dana 20 T/C, Dana 30 Front, Dana 44 Rear 4.27:1, still learning everything about this one, 14 JK pretty much stock
The two wire unit is for the reverse lights. I don't really see any type of sensor connected to that wire on the top of the Transmission , it could be just a ground wire of some sort. Looking at that Transfer Case linkage reminds me what an improvement it is to have a twin stick. I don't recall anything on those plastic plugs though, it has been quite a while since I stuck mine back in.
Thanks folks, Gert, that description makes the exploded view more understandable. Will grab some plugs and seal the holes back up.
Colo Dean,
FIY, the 2 plugs on the Transfer Case , are like gert said , also were used by FSJ`s as "2WD, N, 4H & 4L" lights that were mounted under the dash in a fancy 4 light set. The single wire on Transmission should be a neutral ground for the neutral light, remove and shift thru gears to check. Use the screw in metal plugs like gert said for a better seal with the sealer of your choice.
Single wire connector on Transmission is TCS switch
"Transmission Controlled Spark"
part of the emissions system
it's in the factory service manual
Sorry about that had a brain fart. Really a headache all day. Controls spark in 3rd & 4th.
Thanks Gargoyle, will try to trace this down with the wiring diagram. As it sits, there is nothing connected where the wire comes up to the firewall.
Goes to vacuum solenoid, thru a 3 wire connector from FB back-up fuse.
