Some 350/700R4 Questions
84BlueCJ7
HAHIRA
sounds like you need to regear, what size tires are you running?
Thats what I figured! I have 32's right now. Speedo is correct. If I do need to regear I have no idea what to get. 3:73, 4:10s. You guys are gonna hate me but I don't do any off-roading. Can't afford to break anything any more.
Oh, I can cruise with the lock up dis-engaged but then I over heat in the summer. Transmission cooler sits in front of the radiator. Winter is no problem. 1,700-2,000 rpm seems to be key in performance and power. I don't want to gear too low.
You should measure your tires as most are not as tall as they say. This will affect the results that you calculate.
The power you're getting suggests you're running closer to a race cam than an RV cam.
Now, I'd say that 1,200 RPM is low for 55 MPH and you should probably regear to get it in a better range. And that's what I'd do first.
But I'd also look at doing a cam swap to an RV style. You really should be able to get good power out of that engine down in the 1,200 RPM range.
You can also just leave it out of Overdrive if your only running uder 60mph, then switch it into 4th gear on the interstate. It will not hurt the transmition to drive in third gear, and it is recomended if you are towing. You may even find that the fuel economy goes up because the engine isn't working and lugging so much at 55 mph.
You can also just leave it out of overdrive if your only running uder 60mph, then switch it into 4th gear on the interstate. It will not hurt the transmition to drive in third gear, and it is recomended if you are towing. You may even find that the fuel economy goes up because the engine isn't working and lugging so much at 55 mph.
Thanks boatguy. I can do this in the winter. I have a manual switch. In the summer time it overheats. Gas mileage is actually worse but thats ok.
What all do I need for a gear change? Is there a complete kit?
You can usually get a master install kit where you buy your gears. You need some special tools to do the swap but it's not brain surgery. You really want to make sure you get the parts installed exactly right or they'll wear prematurely and you'll have to do it all over again.
You are definitely lugging the motor. My '82 has 2.73 gears with the TF999 on 31" tires and that's barely liveable. Sure I am at 2k at 70 MPH, which gets me 20 mpg, but after the lock-up kicks in at 40 mph, 40-55 is sluggish and bad mpg. If you're not going to off-road your Jeep, I would look into 4.10 gears. 4.27s are also an option, depending on availability. 4.56s are too much if you're not going to really off-road and 3.73s are not much gain. The 4.10 will give a good bump driveability in stop-n-go driving.
