Steering Some play in steering. Will a stabilizer help?
Macca
FL
77 CJ7, 258
New to the forum
Finishing up on my first CJ rebuild from frame up. A 1977 CJ7 with a 4" suspension lift with spring under axle and another 1" body lift due to new shackles and with a 4" dropped pitman arm.
I am goin to put 34" tires soon. I have power steering and the steering shaft and box is tight with only 5600 original miles but i have some play in the steering between the linkage and steering shaft when moving steering wheel left or right. I looking for advise whether a steering stabilizer single or double help?
A stabilizer won't help with play. Infact it can exaggerate it by putting more friction into your steering system.
How much play do you have. What do all the ball joints and tie rod ends feel like. A common misconception is how to test ends and joints for wear is to just move them and see if they are tight. The correct way is to see if the ball can be compressed in the ball socket. The easiest way to do this is a big pair of plumbing pliers (commonly called Channel Locks) and try squeezing the joint from the nut side to the socket side.
Also, just because it's a new steering box I would snug up the gear mechanism. On the top of the box loosen up the lock nut and using an Allen wrench slightly tighten the adjuster then lock it back down.
I would still add a steering stabilizer to help with any bump steer you might have.
Have looked at our troubleshooting guide?
I will agree that a stabilizer can hurt. It certainly won't help.
Tie rod ends and ball joints would be my next thing to check.
You could be dealing with what I'm working on. My spring bushings are beyond shot and the shackle is moving side to side. I also have a frame side shackle mount moving as well. I'm replacing everything, and welding my shackle mounts in place while I'm in there.
Finally, the steering gear mount plates could be moving. I upgraded to a Mountain Off Road steering box bracket and their brace that ties the box over to the passenger side frame.
I too have a 4" suspension lift, drop pitman arm, and slightly larger tires than you mentioned - at 35". I had some play in my steering as well. New tie rod ends, new ball joints top and bottom, and I also discovered that on one side I had worn wheel bearings allowing the driver side wheel to wobble a bit. Discovered while doing other work on the front end with the wheels lifted off the ground and saw that the driver wheel could wobble up and down even after the new ball joints. None of these items are a big deal to deal with. Fairly straight forward to replace parts and not too expensive either. I also recently found that the lower steering column bearing, the cheap stock nylon assembly at the lower end of the column under the hood, was allowing some play even though it was fairly new. I replaced it with a Wolf unit and am quite pleased. My steering is solid and I can easily do 70mph on the freeway with no play. Now it's not a modern rack & pinion type feel, but it's all good.
This is all great info, thanks all.
Springs, shackles are bushings are all new, so i will Il start by tightening up the steering box then go to drag links and ball joints and then ....
Very much appreciated
Good call but I'm saying a little backwards.
Look at all your joints first...
Sorry to be late again but the steering box is most likely your non issue.
Check and replace your ball joints.
