Spark Plug / Distributor mix up?
DLGATOR
Piedmont, North Carolina
1979 CJ-7 Roadster (1" body lift)
258 In-line 6, T-150 transmission, Dana 20 transfer case, AMC 20 Rear and Dana 30 front axle.
On the new distributor cap you will be adding there is a marked location for the #1 wire. There is a specific firing order located on the intake manifold, but it really doesn't matter where it starts at. The Team Rush upgrade will help prevent spark arcing inside the cap. You could have other issues happening when you step on the gas, like your rate or amount of ignition advance. Actually your distributor/vacumn advance looks correct.
^^^:agree:
$45.00
  22.5%
