Engine Spark plug sleeve leaks
RI CJ5
North Kingstown, RI, USA
1980 CJ5 with a 1980 AMC 360.
4" lift 33" Coopers.
Fiberglass tub
I vave a 1980 CJ5 with a 1980 amc360 from a grand wagoner. Went to change spark plugs and found a sleeve on #8 plug. Was able to get it off put it on new plug and get it back in but now it's leaking exhaust from around the plug. Is there something to put on threads to stop leak or do I retread with a larger sleeve or something else? I won't reserve myself. I'll have someone else do it but if I can just get a new sleeve same size an reinstall I will.
Thanks in advance!
I'm not sure what you mean by a 'sleeve' and how it is leaking exhaust. The only way you can have exhaust blow by a spark plug is if it is not tight.
What is that? A pic perhaps...
Maybe a spark plug non fouler
