start and run problem
Greg
- Toledo
- 1978 cj7 258-6cyl single bbl,400 turbo,automatic,borg-warner transfer case,not sure on differentials yet.
when i try to start my 78 cj AMC 258 i6 / 4.2l 6 cyl. it start's then dies,as long as you hold the key in the start postion,it will run,but when you let off the key,it dies,i talked to a guy,who told me it sounded like a ballast resistor problem, i looked for a resistor @ the firewall,but did'nt see one,i wondered if it could be a starter solenoid problem,or possibly in the ignition switch.has anyone else experienced this problem? any help on this would be appreciated.
i got under the dash and moved wires around on the ignition switch, i drove it around a couple different times,and have started it a dozen or so times,it seems fine now, but is scary because i dont know for sure what the problem is or when it might do it again.
That's it - bad ignition switch.Bad ignition switch maybe?
So did the new switch solve the problem?? I have a 78 CJ5 and it does the same thing... If I touch the wires under the dash it dies... Then I move them again and it will run...
I agree with you Sasquach, it sounds like a bad connection.That does not sound like the switch, but does sound like a bad connection.
Try this place: PROSPERO'S GARAGE Presents: 11" x 17", Laminated, Full Original Color Wiring Diagrams for Motorcycles & Vintage Sports Cars!any ideas on where i can get a simple wiring diagram for the ignition? i think its just a loose or broken wire as well...thanks
How close to orginal wireing does it get? My chiltions has a good wireing diagram but some wire colors on the dia, and my 86 don't match, not to metion the po before just cut and patched in simple on and off switches for the heater fan motor control, got that one figutred out, working on the wipers and light switch. Got all gauges to work and most of the dash lights to work have some ordered. The site you show only goes from 71-81 and later models to come.Try this place: PROSPERO'S GARAGE Presents:* 11" x 17", Laminated, Full Original Color Wiring Diagrams for Motorcycles & Vintage Sports Cars!
I just bought one of these and I love it.
I hate tracing down a bad connection like that. If you get out the multimeter then you bump the wire and everything tests good. I would just wiggle wires carefully to get to to die. See if you can tell exactly what wires are causing the problem. You might want to remove the trim at the base of the steering wheel. Start to remove the ignition switch but just reconnect it. By re-doing the connection you might make it better. I really think the problem is a bad connection at the ignition switch.
