Swap motorcraft 2100 for a 4bbl carb on a 304
Sc37206
Seattle WA
1974 CJ5, 304 V8, t15, D20, D44, D30
(Sold: 1975 CJ5, 304 V8, t15, D20, D44, D30)
Do you have to use an adaptor or replace the intake manifold to switch from the stock carb to a 4bbl in a AMC 304 ?
If you have the 2100 carb, then you need to change the intake manifold if you want a 4-bbl. An adapter won't do for that kind of swap.
Edelbrock makes great 4 barrel intakes, the old carter 4 barrels have a narrower bolt pattern than the Holleys, a lot of intakes are made with both bolt patterns just be aware of it.
Also the Q jets and thermoquads are their own animals
Quadrajets and Thermoquads are two of the best carbs out there for street use and slower trail driving. Their metering circuits are much better than Holleys.
Thanks everyone! I really appreciate the info!
Mriplaybass, the top end was redone and I believe they upgraded the cam. Would that warrant the 4bbl? Im happy to keep it stock if there isn’t much of a difference. I’ve heard the converter won’t produce the same results as an actual 4bbl manifold. Do you think the difference would be noticeable? Honesty, the engine already spins the bfg 31’s and will chirp in second if I get in it too much and that’s with a poorly tuned, vacuum leaking carb.
With only a mild cam, I would probably stick with a 2bbl. You are right, adapting a 4bbl carb to a 2bbl manifold is more for show than anything else since you are still breathing through the same intake.
$35.00
  17.5%
