Swap motorcraft 2100 for a 4bbl carb on a 304
Sc37206
- Media
- 6
- Seattle WA
- 1974 CJ5, 304 V8, t15, D20, D44, D30
(Sold: 1975 CJ5, 304 V8, t15, D20, D44, D30)
I kind of went the opposite route. I had installed an Edelbrock 4bbl intake when I rebuilt the engine in the event that I ever wanted to go with a 4bbl carb. Fast forward one year, and we decided to go with a Holley Sniper. By that time Holley had come out with a 2bbl version of the Sniper, and I felt it was a far better fit than the 4bbl model would be. So now I sit with a 4bbl manifold, wanting to put a 2bbl Sniper on. What i ended up doing was purchasing a 2bbl to 4bbl adapter from Summit Racing and putting it on upside down. Problem is, that this exposes an area under the Sniper where the gasket is the only thing protruding without 2 surfaces to sandwich the gasket in tightly and prevent any vacuum leaks.Do you have to use an adaptor or replace the intake manifold to switch from the stock carb to a 4bbl in a 304?
