TCase T-150 and Dana 20 Leaking oil at joint
Transfer case
calvintitus98
Northlake, TX, USA
'76 CJ7, 258, t-150, D20
Hi folks, new here. I have a 76 CJ7 with a AMC 258 i6 / 4.2l , T-150 and Dana 20 . About a year ago I rebuilt the t150 with a novak kit, also swapped tcase gaskets while I had it out. I seem to be leaking oil at the joint between the t150 and d20. When I pull the t150 fill plug it appears to still be full, and the breather of the d20 doesn't appear to be the source of oil.
Leak seems to be on the middle or bottom half of the joint and I'm looking at the D20 from the rear. Anyone had an experience like this or common places for the d20 to leak from? Again doesn't seem to be swapping oil from the Transmission , as it appears to still be full.
Looking for any experience, places to look, or any tips on how to locate the leak.
Thanks in advance!
Smell the leaked oil and you might be able to tell which unit is leaking. TC oil is quite pungent. The TC/Transmission coupling point is not an oil seal point, to my knowledge. You might have a failed oil seal on either unit. Good luck.
TCase Dana 20
