T-150 to T-18a transmission swap. Instructions for dummies?
Christopher
- Vancouver Island, BC
- ~1977 CJ5~
258, Dana 20 case, Dana 30 front, AMC 20 Rear.
So, in preparation for our trip, I've decided that its high time I install the T-18 that I've been stubbing my toe on for about 3 years.
This T-18 was in a CJ5 , same year (1977) as mine. It has the 1" adaptor on the back for the Dana 20 Transfer Case .
Now, in reading this: Swapping a CJ T-18 into a CJ
And the TSB regarding removing the Transmission , it would seem that the order of operations are: Support engine and clutch housing, remove bolts securing the trans skid plate, remove bolts holding trans to bell-housing, and then remove transmission and transfer-case still bolted together, and bolted to the skid plate.
Is that correct?
Also, I need to grind a clearance arc in my clutch fork correct?
Do I need an alignment tool to align the clutch/etc before I stick the "new" transmission in?
My T-18 is missing the little "pin" that holds the shift lever into the shift lever control housing. Is this just a small roll pin? Or is it solid stock?
I'm a little nervous about this swap, having never done one in the past. I really hope those skid plate bolts don't break off. I've been soaking them with penetrating oil for weeks in preparation.
I do have the drive shafts out of the old CJ5 as well, so my lengths should be fine.
I have a 2 1/2" spring lift, and 1" or so of body lift on the fibreglass body. Do I need to space my skid plate down 7/8"? This is a daily driver rig, and we are about to go on a road trip, from Victoria BC to DeathValley, so it sees a lot of highway miles too. If I need to space it to keep the u-joints alive I will.
Am I overlooking anything?
I'm really looking forward to going slower! Currently the Jeep is way too fast off road.
Thanks in advance.
Part of me thinks I should put this swap off until after the trip. But I really want that low gear!
Is that correct?
Thanks in advance.
