T15 Cover - What's This?
Spring, Texas
1975 CJ5, 304, 3-speed T15, D20 xfer case, D30 front, D44 rear, 5" lift on 35's,
One is more than likely a reverse light switch, the other no idea.
My T-4 has 2. Backup lamp switch & Fifth Reverse lever pivot bolt and lamp switch according to the according to the M R 252 shop manual. On yours I don't know
One is back up light switch.
The other is called Transmission controlled spark switch.
It's part of the emissions system for your year and model.
The other is called transmission controlled spark switch.
Curious what the function is of the second one ?
In a nutshell:
It cancels out the distributor vacuum advance when Transmission is shifted into high gear. This is accomplished thru an electric controlled vacuum switch which vacuum passes thru on it's way to the distributor vacuum advance.
This is the nutshell version.
$35.00
  17.5%
