T15 - D20 oiling question
BC CJ
British Columbia
Early 1975 CJ 5
304, NP435, AA, D300, D30, D44
Hi folks, I finally got around to checking the drivetrain oils on the jeep I bought this spring (haven't been driving it). Here is what I found:
Nice clean oil all around but... the T-15 level was about an inch below the filler plug and the Dana 20 was hugely overflowing. I know these two units are not sealed from each other so maybe the oil from the T-15 has made its' way into the Dana 20 . The T-15 fill plug is significantly higher.
So the question is: should I add oil to the tranny or will that just cause the Transfer Case to be far too full? Is about 1 inch down going to provide enough oiling for the tranny?
Thanks!
Engine Oil
