TeamRush Ignition Upgrade
I have completed the initial stage of this mod on my 86 CJ and it made a heck of a difference. It runs smoother, starts better, and is overall a much better driving Jeep. So far all I have done is install the larger Ford cap from a 300 six, a set of wires, and plugs. I used stock Autolite plugs gapped at .042 and I get good coverage of the center electrode by the ground stap.
Next for me is the nutter bypass and an MC 2100 carb.
If you go to NAPA for a strait 6 get the following:
Distributor cap - Part Number: ECH FA136
NAPA AUTO PARTS
Cap adapter - Part Number: MPE FA139SB
NAPA AUTO PARTS
Rotor - Part Number: ECH FA159
NAPA AUTO PARTS
There are several choises for wires from MSD to OEM. Here is one choice from NAPA - Part Number: BEL 700230
NAPA AUTO PARTS
Thanks bustadave for going above and beond to help with this mod:notworthy: With part #'s in hand how can you go wrong!!!:chug::cool: I've already ordered the motorcraft wires sujested in the first post, So THANKS ALOT!!!!!!!
Well even with the part #s in hand one napa store told my wife they couldn't order the part and that part #s on the Internet are different then theirs, what the :censored: and the only one they had was the same part # but had a Sm at the end and it was the cheap aluminum terminals. So need less to say I went to a different town and napa store and guess what they had that part # in stock an I finally have all my parts, just waiting for my boys to get home from school to put the parts back on. BustaDave I'd hate to bother you again but where did you get the msd cdi ignition module and what kind of price am I looking at.:chug: The resign filled coil and module are next when I get the cash.:cool:
Yes, JR the only difference between the Autolite 645 and 65 is the gap and the hear range. The 645 has a 0.059" gap and the 65 (OEM) has a .035" gap. The heat range is also slightly differently.
I have never switched to the 645 because my plugs are almost new. I plan on replacing the plugs early summer.
I am now running Autolite 65 gapped at .044"
They are working good but I would prefer to go to Autolite 645
Bustadave I've got the cap and plugs wires done on this mod and was wondering if I had to wait until I replaced the ignition module before I start to try and open the gap a little. Still saving for the ignition module and coil.:)
With a bigger cap and wires you can gap your plugs at 0.45" to 0.50"
When you install the MDS ignition module you can gap your plugs at 0.50" to 0.60"
OEM was 0.35"
I have some useful information for anyone doing this upgrade.
First I'd like to thank BusaDave9 for helping me over the last couple of days in diagnosing an electrical issue I've been tackling regarding this upgrade.
For a complete read of my problem, look here:
http://www.jeep-cj.com/forums/f2/ignition-system-electrical-issue-12289/
The net result of my MSD ignition installation was this:
I couldnt shut OFF my engine.
The net fix was to install a diode, radio shack part number 275-1143 on the small "excite" wire on the back of the alternator. I have attached pics of the diode used. The band on the diode must be installed TOWARD the alternator.
Apparently, I had alternator current "backflowing" through that wire to the ignition switch. When I turned off the key, there was still 12 volts, actually 14 volts of alternator current in the igniton key "on" wire.
I can only assume there must be a built in "restriction" or diode in the brain unit that went away when I got rid of the factory brain unit to install the MSD igntion module.
So, after replacing the starter solenoid and alternator with a spare from my parts shelf, I got hold of JeepHammer. Yes, JeepHammer. The advocate of this MSD ignition upgrade.... "Mr. TeamRush"
Before I fully described my problem, he knew what the solution was.
So, hats off to JeepHammer. I owe him a handshake, a beer, and a thankyou.
To any of you doing this upgrade, be sure you include the diode in your parts box before you start. I have been told that MSD includes this in the purchase of their module, but I bought mine used and never had one. NOT to say you WILL NEED IT, but if you have a similar issue, this post might save you time and headaches... (and a broken electrical meter/tester that somehow flew across my garage and hit the wall)
Thankyou Dave for the continued interest in helping with the diagnosis and guidance along the way.
Thankyou JeepHammer for the easiest cure of the day!
brian
Dave, my first thought after finishing the upgrade was: WOW, it sure starts fast!!!
It used to take about 3 or 4 long seconds to get it to fire (at best), but now I just have to bump the key and BAM ..... she's running!!!
I have other issues to tackle now, but I can see the immediate difference just in the first few seconds..!!
Busa, I had a similar setup on my 83 Scrambler, but you might consider one more addition since you live in Durango.
MSD Adjustable Timing Control
Adjustable Timing Control - 8680
I also live in Colorado, lived down on the flat, but spent a LOT of time above 7500 FT Elevation. This control allowed me 15 degrees adjustment in the timing from the drivers seat. Set your usual timing with the knob in the middle and you have a spread of 7 1/2 degrees adv or retard. This resulted in radically better driveability at all the elevations I ran at. Eliminated any sort of pre-ignition, etc.
For those doing the bypass on a 2.5L I just read an article on the Cherokee forum that deals with the Carter YFA modification to make it work with the upgrade. I didn't know if this had been posted here or not, forgive me if it has. Andre. Link:
The 2.5 YFA XJ Nutter Bypass (plus) - Jeep Cherokee Forum
i would love to do this to my jeep, except i cant afford the msd 6. if i go with the streetfire will it wire up the same as in the diagram and would i need the same extra harness?
