Build Thread The $120 Jeep CJ7 build thread
Sweet looking good
Took off the front spring front shackle mounts yesterday. Did some cutting and grinding to get the rear spring mounts for the front springs off the frame too., One easy, one a PITA. Got the I-6 motor mounts off.
Started to take off the steering box off and one of the bolts snapped off in the frame. This is gonna be a real PITA. These bolts go right into the boxed frame. Any ideas on how to deal with this?
The steering box will get replaced with a fresh unit, and I could just weld a short bead at that last bolt hole location (it's the rear hole) but I want to keep so it can be removed again if need be.
I hate wrenching on a bare frame. These rusty bolts are on so tight, and the frame has no weight, so it just wobbles around on the jack stands...
I used to work for Fed Ex, UPS does not treat heavy items any better than them.
In their defense, if an item is shipped naked I would imagine the thought is it must not need careful handling. This one falls in the shippers lap. IMHO, YMMV.
(I’ve always wanted to put those two together......)
Sent from here using Tapatalk.
Sent from my iPhone using Tapatalk[/QUOTE]
I've been in the shipping business on & off for the last 40 years. If items aren't well protected, those two companies really could care less about your stuff. I've seen their people ( brown ) toss boxes 20 feet. USPS is not much better
Lol no they definitely don’t care
Try WD40 on the sticker, it loosens the sticker and paper up pretty good
I just happened to have some WD40 right there in the photo...
That stuff is so good, I eat it on toast.... LOL
LMAO - I think he mighta meant the stickers..... just spitballin here....
Oh boy on the sticker I don’t think it will taste good[emoji23]
Good point. The toast would be a better option.....
Looking good, cutting and drilling frames are nerve racking things to do so don’t worry about that, I have had quit a few 1/2 inch drill bits catch and pull the drill right out of my hand as well so don’t think you are weak for that
$125.00
  62.5%
