Build Thread The '80 FrankenJeep frame off reassembly
Just for the record - Anyone planning on a new loft gate gasket from Fairchild - better wait till warmer weather.
It looks very nice, fits perfect, and feels nice and spongey - but the dang thing smells like a mixture of new tires, a dead skunk, and cat pee. Getting in it to go to work will definitely wake you up!!!!
Sounds kinda like getting stuck behind a garbage truck for 10 blocks around here the Tuesday after good Friday when everyone has eaten a lot of crawfish & shrimp and things have ripened In the heat a few days. Pretty disgusting.
Oh, man - that may be worse than the gasket......
They look pretty good !
They look better than the dang top
They look great with the texture and love the Chewy work stands. Have several of those here too. As well as the Chewy garage floor liquid spill barriers,
I’ve been known to use Chewy’s welding tables..... but ya gotta work fast - bein flammable an all
Got the door seals glued back into place..... supposed to rain most of the rest of the week, so I’ll probly just wait an swap doors this weekend. Guess I should take the locks out of the doors and get a key made for em. Nope - no pics.
It got pretty cold here with the front that moved in yuck
Don’t recall how cold it’s supposed to get, but they’re calling for 3” - 5” of rain tomorrow. Stuck a set of oars in the Jeep just in case.
Sent from my recently completed ark...... Gonna be a wet couple days.
I just reread my earlier post.... man, can I butcher words or what?? I’m assuming you’re asking about the pins on the soft uppers? Those uppers were YJ uppers so the pins matched the lower. TJ’s have a different pin setup - one is inboard of the others by about an inch and a half. But these uppers had no pins, only holes for screws. The inserts in the lowers have retaining fingers on the bottom that are supposed to hold nuts for the screws. Mine were missing the nuts so I just figured the fingers applied retaining friction to the upper pins. All I had to do was fill and redrill the offset hole. The spacing between pins / holes on the TJ uppers doesn’t differ from the YJ spacing - ya just hafta make sure they’re all aligned in a straight line to fit the lower. And man, these are so much more comfy to use..... you don’t realize how much room is taken up by a full hard door.
Sent from the rifle cleaning bench...
Understand now. Thanks. I have TJ soft uppers on my YJ half doos and the rear pin does not align with the hole on the YJ door. I cur one and welded it poorly. The weld did not hold. The other one I left the pin and it presses against the door card.
I was thinking about hard upper sliders, but I have a set of full glass doors with sliders so I just use those if needed.
That’s the route I would have taken.....
My goal was to run the half doors year round, but my soft uppers would not fit the hard top. Picked these uppers up for AMC 150 bucks so I had to make em work. Now I can leave the hard lowers on year round. After a couple rains I’ll evaluate and if everything works as it should I’ll sell the full hard doors.
