Build Thread The '80 FrankenJeep frame off reassembly
Wow I'm going to have to remember that when I put my mounts on
I saved the pic in like 20 places so I might remember at least one - and I only have a week or two to go [emoji16]
So, I'm :booze: dumb. Why would the rubber puck that goes under the body mount that is attached to the frame have to be thicker on the front than all of the other?
If you mean the core support (front) it's the way Jeep designed it. Probably because the core support is only attached to the frame in the center, the fenders and the two support rods. As the frame and body twist the support can rotate about the center easily. Thicker rubber helps minimize stress on the support while allowing more articulation.
I had no idea either - but I remembered seeing somewhere that two of the cores were longer than the rest. I never questioned the why, just the how long LOL
Man putting some work into it, looking good!
something to consider. I sprayed aerosol rubberized sound deadner on my old tub firewall and it left a million pin holes in its surface. I painted over it with gloss black and the pin holes filled with mud that would not come out at all. So I had this nice shiny black paint that had a million brown specks in it. I think on my new tub the inside will get a good thick coat of Line X to help dampen the sound
In my case, the only place the aerosol is gonna get used is on the firewall. Everything else bedlined will most likely be Monstaliner or Raptor........ The stuff I just used went on well. I applied a light coat first, followed by a fairly heavy wet coat, finishing up with two light coats for texture......
Never heard of that...... Gotta read up on it.
Had a few thin cutting wheels explode like that. You are right, it's an adrenalin rush, sometimes it even hurts some.
Good job on making everything fit back together! It's gonna look like a Jeep again! ;)
Nice Job! Gonna look awesome!
$150.00
  75.0%
