Build Thread The '80 FrankenJeep frame off reassembly
Yeah, the under dash wiring is NOT on my "wanna do" list......
I would be sure to add some sort of rear support for the radio. That way it won't rattle around. That cage is not strong enough to support the radio by itself. I actually welded a couple of brackets on mine to support the radio. In your case a piece of light weight metal strap attached to the rear mounting post could be bent up and over the radio, then attached to the dash.
Yeah, while I have the dash torn down I am gonna rig up some kind of support bracket. Don't have a rear mounting stud, but will definitely rig something up.....
Awesome job on the gauges! Keep the pictures coming, I'm sure there are others out there that will follow your lead and repair theirs too.
Fantastic detail and :ty: for the detailed posts. :notworthy:
When I have rebuild gauges. I found using a can of compressed air to remove dust/crud from the internals, to be a great asset.
I agree - but lacking a can of air, I used the compressor LOL. Had to not get carried away with that....
I have found that the 'hollow' nut on the gauge GND will come loose over time. I would use a 'real-nut' in it's place.
On the dash GND-The paint needs to be scraped off where the washer makes contact. Cover bare metal with battery terminal spray.
Nice work!
Yeah - That was just to hold everything in place while I was working. I'm actually gonna replace all those hollow nuts with thumb nuts..... that sounded funny, Knurled nuts you tighten with your fingers. Finger nuts? knurled nuts? :chug"
That's cool. You cut the entire thing out of a solid piece of vinyl? I don't think I have hands steady enough to do that.
$150.00
  75.0%
