Build Thread The '80 FrankenJeep frame off reassembly
Wow dude your Jeep is lookin so good I see your missing your radiator is there anything else stoping you from driving it? I love that red even more now that I see it mostly together I think you did a great job painting it
Sent from my couch using Tapatalk
Nothing major, just a lot of small stuff.... radiator and hoses, all lubricants, rear drive shaft, mount and wire coil, battery, power steering lines, brake lines to the master cylinder...... and seats.
I really like this color as well - best part is the metal flake isn't visible unless it's in direct sunlight...
Looks great. And the flares finish it! Congrats getting it turned around solo.
It really does look great. And the silver bolts look good to me Maybe I should just swap bolts with you :)
:agree: You have done a great job. Is the rollbar a YJ bar with a bar added behind the seats?
It is a YJ bar. The bottom mounts were bad on the CJ bar and I got this one stupid cheap to transplant the pads. Then the box idea hit and the spreader bar helps prevent the windshield frame from quickly moved forward. The added cross bar is for the possible future addition of 4 point harnesses.
Sent from my fridge using Tapatalk
Does the YJ roll bar fit exactly as the CJ bar ? Sent from the outhouse
I HAHAHA - one holer??
I believe they do, but I have a YJ tub as well. Still had to slightly slot a couple holes. But it’s my understanding the YJ sport bars will drop right in
Sent from my gas grille using Tapatalk
I thought it was because you have a YJ W/S frame and it would bolt right up.
Oh, yes - the spreader bars bolted right up.
Well if it helps I have a YJ tub with a CJ roll bar and it bolts right up
I think other than the spreader bar attachment points the CJ / YJ sports bars are the same. Matter of fact, the bar that came in mine was a CJ bar that had the holes drilled in it for the spreader bars and that works fine
LOL - No, they’re high dollar stuff. Harbour Freight.
oh boy watch out Shum8 I found another idea for ya
HA 😝 - I’ve seen that one before....... However - have briefly mulled the idea over for a guava surround - using walnut veneer......... LOL.
But I appreciate the help finding uses for all my free time 👍
Lol you have given me plenty of help with ideas for all that free time I have [emoji23]
$150.00
  75.0%
