Build Thread The '80 FrankenJeep frame off reassembly
Yes he has a YJ tub as I do, I am conflicted on whether I want to modify my tub to fit the CJ windshield washer or leave mine like Shum8
I just put the originals back in. Otherwise, I’d have to fill in the holes. More work. I’m all about easy now........ I had misplaced em for a while, and you can’t find em anymore. Auto parts stores sell replacement nozzles, but none will work. I was beginning to sweat it when I found em.
Sent from here using Tapatalk.
Oh boy I guess I better not remove mine then, I have a bad habit of loosing small stuff myself
Just put em in a zip-loc bag and hot glue it to the windshield....
Lol what my cracked needs to be replaced windshield?
Glue it over the crack - kill two birds with one stone kinda thing.....
I would just go with what you have, not worth modifying it !
Agreed. I would leave it with the YJ washer set up. I would like to switch my sprayers out for YJ or later nozzles. The way my CJ ones spray is not optimal. It works, but I would prefer a wider spray pattern.
Oh boy looks like your having to much fun
[emoji106][emoji106]
Sent while sitting in the litter box using tapatalk.
Yesterday while I was fiddling with the idle some more, I took a break from the carb and started checking to see which dash controls didn't work. Turned the fan on - low worked, med worked, and high worked. Cool. Stuck my hand down at the heat outlet and was really disappointed in how little air was moving. Even with the blazer blower motor upgrade, and it was pitiful. I then realized the vent knob was in the "closed" position. I gotta get my head back in the CJ controls game..... I pulled it open to the floor position..... HOLY SHIZNET!! Talk about moving some air!!! It blew dust, pollen, dirt, papers, and whatever else was in the floor, to the back seat area. If this thing has nothing else, it'll have heat!!! Once winter makes its return, I'll have to drive naked to keep from melting LOL
I sent this using Tapatalk.... And I'm standing RIGHT next to you.
Maybe you can use some of that heat in the two hole out house this winter when you are ice fishing at the lake Sent not using Tapatalk from the alligator infested swamp
Man that’s lookin good Shum8
Sent from the past using Tapatalk
That really does look great. It's a real shame you have to cover it up with a spare!
That’s ok - I’ll know it’s there...
Sent from an undisclosed location on an unidentifiable device possibly using tapatalk.
I have the cheap Chinese aftermarket ones and they look worse than yours lol, those should do fine, they are packed with mud like mine
$150.00
  75.0%
