the motorcraft 2100-2150 2-bbl carb. and related posts
CJ BRIAN NJ
- JERSEY
- 1979 Cj-7 Origional numbers matching 304 3 spd with dana 44's.,
89 cherokee,
91 cherokee,
95 grand cherokee 1/2 soft top chop,
cj-5 Tuxedo Park edition year unknown,
hey guys im having a carb issue with my 79 CJ7 carb. its a motorcraft 2100(or 2150 no id tag) on a fresh tight AMC 304 that has plenty of power and runs great . it wont idle unless i manually push the choke almost completely closed. im not sure how the idle circuit is designed in these carbs but i know on some the vaccum sucks a little gas from the bowl to keep it idleing . but i only see gas in the carb when i pump the accelerator pump . i have ran a few gallons of super unleaded through it with fuel system cleaner and that didnt get me anywhere. is there a port or circuit in the carb throat that i can see the idle gas getting pulled in to the motor
here is the description i put in my build thread to help you guys understand my problem!
it only gets gas from the accelerator pump there is no gas getting to it at idle so it dies. if you pump the gas petal it runs great very strong and revs out quick and clean.it just wont pull fuel at low rpms. should i be able to see any gas moving in the carb like i do when i pump the throttle. the pump squirts strong and nice and even in both barrels but if i dont keep pumping the venturis go dry and i dont see any gas in the carb throat then it konks out. i know in some carbs you can see the idle gas being sucked out of the bowl or idle circuit but i see nothin!
Read more: http://www.jeep-cj.com/forums/f98/1...g-restoration-13704/index5.html#ixzz2DDHtzZh4
