Trans/axle oil change help
Gclyne
Indiana
1978 CJ5, 258 I6, T-18a, Dana 30 with AMC 20. 4 inch lift, 1 inch shackle lift, 1 inch body mount lift, 2 inch spring lift. 33" all terrains. Daily driver, 60k miles. :)
Any help please?
There are two different locations for the fill plug on the Dana 20 . They are circled in red here:
Here you can see the T-18 drain plug on the bottom of the Transmission and the fill on the side by the pto plate :
http://s39.photobucket.com/user/Cjpete85/media/Jeep stuff/imagesCATWQ2J3_zpsdd898ca6.jpg.html
I would recommend that you purchase a FSM or a service manual from your local part store.
The T-18 does not share fluid with the Dana 20 . There is no need to use GL4, I used GL4 for years in my T-18 but the GL5 has improved to a point where I'm comfortable using it. If you feel a need to use GL4 Napa carries the sta-lube brand. The best and easyiest way to fill your tranny, Transfer Case , and diffs is with a hand pump. They can be purchase locally or online. The one I have is a pump and lid that I install over a 5 gallon bucket of 80-90 weight gear fluid.
Something like this
http://www.zorotools.com/g/00059700/k-G0497594?utm_source=google_shopping&utm_medium=cpc&utm_campaign=Google_Shopping_Feed&kw={keyword}&gclid=CMuzpYyU77wCFfNxOgodcygA-w
Hope this helps
Times 2 on a REAL, FSM. ;)
Chilton and Haynes just don't cut it!
Look up Collins Bros. Jeep.
