Trans fill plug
Fill plugs are not always Transmission specific, a pic would help here. Right off hand though, if it is an exterior hex or torx, you could probably use a vise grip. If an interior hole type, it might require a large easy out for a broken screw. Then replace it with a more standard square or hex head. They are usually a 1/2" pipe thread. My $.02
Mine's a 4-sided convex
Sorry guys. This is a fill plug on the passenger side of Transmission . There id a pipe plug on the opposite side just lower than the fill plug on the passenger side. I believe the pipe plug on the drivers side is the sight hole. I found an allen that fits the fill plug but it's hard to get to. I think instead of checking level, I'll just change the fluid out while itcs hot and will drain. That way there's no doubt it's full.
I got it figured out. Checked the levels in the tranny and Transfer Case . All good to go. I'll change them out in the near future. I didn't immediately get oil out of the fill plug as the manual states so I added a couple pumps of lube ril it started to come out. Transfer case was still full.
Make sure your tranny and t'case vents are clear of crud and working.
There should be hoses going to each of the vents. The hoses go up into the firewall to provide venting and high enough for deep water crossings. The diffs should have them also.
In my CJ none of them did that, so I had to look a little closer to find them.
I'll have to look today. I know I have both vent hoses for the diffs. I don't remember seeing any other vent hoses.
I think vents with riser hoses are a great idea, but non of my CJ's had then. My transfer cases had/have them on the top on the rear propeller shaft housing. The transmissions had them on the top behind the shifter. Both have a lose fitting sort of a mushroom shaped cap.
Trans 81 CJ8
