Transfer Case Shifting Hard
81laredo
Idyllwild, CA
1981 CJ7 Laredo as built, 1952 Pontiac Sedan Delivery, 1955 Thunderbird, 1958 Airstream, 1996 Tahoe 4X4, 1982 Newell Coach, 1957 Cabin in the Woods what will I work on next?
The Transfer Case on my '81 CJ7 is hard to shift sometimes. Is there an easy fix? I replaced the motor mounts earlier for another reason but I haven't replaced the Transmission mount.
thanks in advance.
twin stick it :) the best thing I ever did for shifting problems.
or check (clean) the linkage where it bolts to the tc, it gets all gunked up there.
You should have the Dana 300 Transfer Case . They have a history of not being able to shift very easily. There is a proper way to do it though, and that is when you are shifting into 4wd is to be at a slow roll of 2-3 mph while engaging, that is from the owners manual. I also have converted to the twin stick and find it easier to work with.
Thanks, I have found it easier too shift when on a slow roll as suggested. It sounds like it may simply be the nature of the beast.
Thanks again
