Transmission cooler
jeepboy45
Old Time Jeeper
- Altamonte Springs, Florida
- 1979 CJ-7, Newly rebuilt AMC 360!, fully rebuilt GM TH400, Quadra-trac TC w/Milemarker 2x4 conversion, AMC mod 20 rear w/1 piece Moser axleshafts, mod 30 front w/tie rod flip and castor correction shims, 4 in lift, Centech complete wiring harness, dual electric fans on 3 core aluminum radiator, tilt steering wheel, 20 gal poly gas tank, new J20 steering box, MSD 6A ignition combined with TeamRush distributor mods
Hi,
I am learning more and more about the sensativity of auto Transmission fluid recently.
It is very important to keep the fluid as cool as possible. Approx 220 degrees, it starts to break down quickly. I recently read that when an engine severely overheats, it is not suprising to find the auto trans develpos problems 2K miles later due to the trans fluid overheating in the shared radiator/trans cooler.
My short story:
I have always had an issue keeping my CJ V8 cool.
For years, I have run a trans cooler directly in front of my radiator. I am wondering now if that is the best place to have it. My intention was to separate the two cooling systems but if they are actually touching (conducting heat) it is probably pointless. Plus the fact that the trans cooler is somewhat blocking a portion of the airflow through the radiator cant help cool the engine temp.
My question is this:
I have the trans/ Transfer Case / radiator out right now and GM Turbo 400 trans is at the shop. My radiator is going to be replaced with an aluminum one, and was debating if I should put the trans lines to it, or keep the separate cooler. If I keep the separate cooler, where is the ideal place to mount it? In front of the radiator? Separated by an nch of space? Behind the radiator? Somewhere else?
Any imput is welcome....!!!
thanks in advance.
brian
My short story:
thanks in advance.
brian
