transmission fluid question
Hi guys,
I have a somewhat recent purchased 1980 CJ7 with sr 4 Transmission and 300 tcase. I am going through changing all of the fluids. I drained as much fluid from both the transmission and the Transfer Case . I reading some posts on here I chose to try the synchromesh fluid for replacement. Transfer case was done with no problems. As I am trying to refill the transmission through the fill hole, the fluid continues to come right back out. I couldn't even put 1 bottle in there. I think more than that drained.
I took for a short test drive around the block and now it wont stay in 2nd gear. It goes in but pops right out then it starts to grind. Did not have this problem before the attempt to swap the fluid.
I think I am going to use a suction pump and remove as much fluid as I can again, since removing the bolt did not (I am guessing) did not drain it all. Then refill and try again.
Any suggestions.
Any suggestions.
