Transmission housing coverplate
Recoil
Texas
1982 Jeep CJ7, 258ci I-6, T176 4sp, Dana 300 Transfer.
Need some advice here,
I have an 82 CJ7 when I purchased it, it had a T-150 3spd. and model 20 transfer. After a little research I found it came with a T-176 4spd. and Model 300 Transfer Case which I have replaced. My problem is the Transmission housing cover I found orig. equip. from a salvage yard but when I shift into 4 low (all the way forward) it hits the cover plate, is there an adjustment on the transfer shifter? anyone ever experience this? I hate to start carving on the cover plate it was hard to find.
Cheers......
Maybe the cover plate is not for the T176/D300 combo. Also do you have the skid plate lowered for driveline angle with a lift? A body lift? If so either could change the angle on the shifter.
Thanks for the info, I'll have a look at the shift levers.
Doesn't take much to heat and bend the lever to fit your needs.
