Transmission Skid Plate - Have I screwed up?
Muley775
This afternoon I set out to change Transmission (T-5 ) & Transfer Case (Dana 300 ) fluids.
Before dropping any fluids, I removed a large skid plate that is bolted into the frame on both sided with three 3/8" bolts, and in the middle (to the transmission?) with two 7/16" bolts, and a third in the middle shaded to the passenger side to a big rubber bumper assembly. I probably didn't need to remove the plate, but I wanted to clean up under there and have more access to inspect - this is a new vehicle to me. After cleaning, I went to move the CJ to sweep up before doing the fluid changes. I was rewarded for my all my clean-up efforts with the terrible sound of the fan blades hitting the shroud. After the initial shock wore off, I figured with the plate off I had changed (removed?) the support for the transmission and the weight of the transmission and transfer case have pivoted the engine on the motor mounts pushing the nose of the engine up causing the interference.
I was having difficulty getting the plate reinstalled. I have the bolts in the middle installed roughly finger tight, but can only get one side or the other of the plate bolted to frame. The other side is too far away from the frame. Again, I'm assuming the transmission is too low, and I thought about using a floor jack to raise things up a bit.
I was running out of day light and also thought I should apply the first rule of holes (when you're in one, quick digging).
I've looked around here for hints, and found this:
and now realize I've stumbled into something more than I bargained for. Talk of a torque arm has me concerned. The loose washer laying in the top of the pan makes me wonder if something had worked loose/broke/wasn't installed properly. That big rubber bumper seemed to be loose on the top side.
So ....
What I have I gotten myself into? Any recommendations?
Am I ok putting a jack under there, lift up the transmission to get the bolts back in where they were? Are there any special adjustments I need to make? If I go this route, get everything buttoned up and the fan/shroud interference goes away, is there anything else I need to be concerned about?
Any help would be appreciated.
Thanks in advance!
I just bought my 80 CJ5 and noticed the transmission mount
Was busted so dropped the skid plate and got a new Trans mount
But looks like I'm missing a piece that mounts between the transmission
Mount and the transfer case.
Please let me know if you know what I'm talking about or
What I'm missing!
Thank you!!!
What I'm missing!
Thank you!!!
- Straplodmc
- Forum: Drivetrain
So ....
Thanks in advance!
