Transmission Type?
Transmission Type?
LIVELY5R
Texas
1980 CJ-7with 258, SR4 4 speed transmission, stock everything that I can tell.
I promise I've used the search engine & tried googling this but I can't find the answer. A 1980 CJ7 I just bought with a 6 cylinder engine has a 4 speed standard Transmission . However it is different than my 1980 CJ5 as the one in my CJ-5 has reverse down & to the right by 4th. My CJ-7 has reverse up & to the left by first. Can someone please tell my which transmission I have?
I will update my info this weekend. I haven't been able to delve into the new CJ-7 much due to work but hopefully that will change in a few days!
Since we don't know if it's OEM.
Why don't you post some pictures of the tranny from each side.
I shall try this weekend!
The stick does angle back toward my driver's seat. I have larger tires on the jeep but it seems much more anemic than my CJ5 so I figured the Transmission was the main difference. The little I have driven it I noticed going from 1st to 2nd was kind of a pain since it wouldn't engage in 2nd gear right away & I'd have to fish for it.
Thank you very much!
Tire size will make a difference, but so will gear ratios. Have you checked out what those are? Big tires and tall gears will be a slug.
Your ring & pinion ratio will play heavy on sluggishness.
