Unknown hole in rear axle??
gadawg31
GA
1979 CJ-5
258cu in 6cyl
T-150 3 speed Transmission
Dana 20 Transfer case
Dana 30 Front axle (almost 100%)
Fiberglass Tub
That looks like a tapped hole where the brake line holder gets fastened. if its on the left side it might be where the line splitter gets bolted down.
If you are looking from the rear end forwar, the hole is on the right, next to the axle vent valve. I have looked in a couple different manuals and can't seem to find it. Maybe someone on here has the answer. Thanks Fast Toys.
JD
That is exactly where it is and looks exactly where I need to put my brake hose. LOL! The PO had a hoses and lines running everywhere and no clamps or brakets, so when I scrapped it all, I had no reference point. I will post a pic of how I laid mine out and know I don't have to worry about anything leaking from there. Thanks guys for the help.
JD
On mine the brake line
Spliter is on the left. On the right was jusr a clamp for the brake line on that side. Rod
If I don't have any brake lines near there, would it be OK to just thread a bolt and lockwasher into it?
Thanks, I'llcheck for another hole on the other side of the differential as well and work on getting them both plugged up.
