Engine Vacuum line routing '81 CJ7 4.2L
Nikwho
Flagstaff, AZ, USA
'81 AMC CJ-7, 4.2 I-6, 4 speed, ARB Air Lockers, trail rig, 35's.
Hello all, I've been searching old threads and trying to find my answer that way, but not finding exactly what I need.
I just acquired my '81 AMC CJ7 yesterday. It has sat for 4 or 5 months, and 6 months prior to being moved then. I want to freshen it up a bit.
My main question is regarding the vacuum lines. I have a line coming off of the carb, with a few inches of line, then a tee fitting. I'm not sure where that line goes. I'm going to replace the fuel filter and verify that the return lino the tank is clear.
What do these rigs need vacuum provided to? I figured that I could buy a few rubber vacuum caps, bypass mostly anything that has a vacuum hose hooked to it, and run a vacuum line from the carb, to a PCV valve in the valve cover.
Anyway. Im happy that I found this forum! Now, Im off to NAPA to buy a fuel filter, 25-ish feet if fuel line, two engine mounts, a Transmission mount, an oil filter and some oil. Gonna get this rig freshened up, and start driving it.
Here's a great resource for vacuum line routing (for those keeping such). Web Site Link
And could check here as well: Local Link
yeah it all depends on your current engine year and setup, many emission related poo poo lines lol.
Me it's a Brake booster vacuum and maybe a advance to the distributor if required and that's it. Sometimes I'll add an aftermarket fuel eco gauge which runs on vacuum, keeps me from being heavy footed.
Also your heater/vent blend doors may require them if not cable controlled.
Trans 81 CJ8
