    Thank you for your support!
Waggy 44 front axle carrier break?
mylittlecj5
RIP Mike, we'll all miss you
OKC area
'74 CJ-5,
360 AMC Engine.
35x12.50x15 TSL Super Swamper tires.
In a frame off rebuild for a long time...
Whats the break on a Dana 44 carrier? I have a front Waggy 44 thats planned for my CJ build. Its currently got 3:07 gears in it. I want to use 4:10 gears eventually.
Can I use that carrier or do I have to find a different one? Can a guy use the carrier out of a rear axle in the front? :eek:
3:73 or 3:91 I don't remember for sure and yes you can use the same carrier.
Dang, so I can't use this one? Oh well I have time to find one I guess...lol
Thanks OD...
you might get lucky and find a used set of thick gears, or a spacer.
2 weeks, 2 days, 19 hours, 9 minutes, 35 seconds
