Yep. Did you bench bleed that MC before installing? I had a persistent soft brake pedal after I switched to a YJ setup. I tried everything but could ditch the spongy brake. I finally went with a corvette MC and double diaphragm booster. Brakes work awesome now.
Wooly
Wooly
Today I installed a new headlamp switch.
Last week my headlights went out at just before dusk on a grocery run.
About two years ago, the dashboard lights stopped dimming... they were just on or off.
I got the headlights working by vigorously actuating the plunger after a liberal dousing of Corrosion-X. Even so, I took the warning seriously and ordered a new switch.
When I looked at the new switch it took a moment to recognize the rheostat. Now it feels down-right luxurious to dim them.
-Jon
Wooly
No. I did not bench bleed the MC as I never removed it. It stayed connected to the tub the whole time during the frame swap process.
I have looked at the conversion to the dual. And may be headed that way. Thanks.
Posi-Really like'n the wheels! :notworthy:
What size did you go with, and who's the maker?
Pushed the CJ back into the garage :(
Thanks, H2 rims with PB Rockers 39.5 17"
The tire is taller and wider then I wanted, but they were too good of a deal to pass up.
Thanks, :D
Tire shopping next? :D
Haha. You know it. I had these 31s with the 2.5" springs before the frame swap. But the 1" lift I built into the body mounts seem to make a difference.
I upped the gears to 3.31s. Not sure how fbI will go up to 33s or not but 32s at least. But I have a good amount of tread left. 40k miles on these tires so I am sure new ones will come soon enough though.
What do you think? 32s or 33s?
