Bill, FWIW. I get the best range from my CB using a 102" SS 'whip' ant.
I keep it 'folded' over on the trail.
May I ask what antanna you're using?
I used to use a 102" steel whip but decided a 48" fiberglass made better sense rather than deal with a tie-down. At the trail ride this year, Shooby had a slick mount that goes behind the tail lamp assembly and puts the base of the antenna right at tub level. I installed one of these and moved the 48" whip up from the rear bumper. This should give me a better ground plane (plain ?). Later this week I'm going to dig out my old SWR/wattmeter and tune the whole antenna system for max performance. :cool:
A good SWR ratio(1.3 or less)will do more, in most cases, for the radio than just a long antenna.
Please let us know how this works out.
But that saw is so .... oh I don't know ..... so yellow. Can't be a Stihl or Husky .... and that blade is so long. :)
Man I bet the environmental wackos would :dung: in their pants if they saw that power plant running
Wow! What an interesting sound. Not a green question, just curious, I wonder how much oil they burned. A few years I noticed that modern day trains don't smoke anymore. It wasn't long ago that the big black smoke would roll from the diesel electric trains we see today. I guess the day of smokey trains went the way of joints in the tracks.
Fenders and knuckles are cheap.... I bet she's a lot lighter. Now that's a body lift. Is that a home made reverse shackle set up I see?
Some 2x4s for a body lift so I can work on rear crossmember and gas tank and yes I am doing a 2 inch wheel base stretch shackle flip narrowed Dana 44 and spring over in the front, I was in the middle of it when I got a job in Afghanistan now that I'm back it's on hold til my lack of welder issue is solved
I wanna see that in person one day
I have-There's nothing equal to the real sound and ground-shake..............
I've been lucky enough to see 3 space shuttle launches. 1st was in 1983 from my dads sailboat - unbelievable power, the boat was hit by a down wind noise and shockwave. That was before the first challenger disaster when you could get pretty close, maybe to close. Second was a blinding night launch on a clear fall evening. I was lucky enough to be a NASA launch honoree because I work at the NASA rocket factory in New Orleans. It is not an easy thing to see. I have been several other times only not able to see because of technical difficulties and other delays. What I'm really wanting to see is the new rocket just starting to be built to see that launched
