Oh my! I hope the Transfer Case problem is something simple and you make it home safe! Sounds like you didn't wheel just greens. [emoji3]
Sent using Tapatalk
Oh my! I hope the transfer case problem is something simple and you make it home safe! Sounds like you didn't wheel just greens. [emoji3]
Sent using Tapatalk
The more I think about it, it may just be a motor mount or Transmission mount based on the violent shaking that was happening. I will take a look at that before I go and tear anything apart. And I was primarily on blues and blacks.
Removed the body hardware which consist of snaps, brackets, and hinges.
Installed new fuel line in the engine compartment.
When I previously tested feed fuel pressure I found 10 PSI, when I twisted the throttle shaft it dropped to 9 PSI. After installing new vent grommets, fuel line, fuel pump sock, and cleaned all the RTV from the system I now have a spot on steady 12 PSI.
https://youtu.be/AMyjKXRBsUU
Does this coating, help to cut down on 'road-noise' much at all?
I would say it doesn't do much if anything to cut down road noise. A layer of insulation, rug, and a top would do the trick. The Super Swamper TSL's are fairly loud running down the road, I'm sure I wouldn't be able to hear the radio at 40mph.
I mainly added the por patch and rust encapsolator to keep out the weather and rust protection. I'll sand it down and add a top coat. Thanks for the question.
Speaking of tops, I found a new, never installed top, doors, and bows for my 3b at 25% of it's original cost. I'll be picking it up the day I land in Denver.
Last night I began adding a skim coat of plastic where needed on the exterior of the body.
Installed the rollcage inplace to mark the rollcage footpad. I’ll need to cut the pad to match the driver’s side wheel well notch.
Installed dual electric fans. See build thread for details.
^^^ Nice!
Finished welding on the body.
Finished 90% of the plastic skim coat.
Today I successfully updated the Holley Sniper firmware for the handheld unit and the ECU. Then we took it for a drive. This latest version is supposed to learn and control better. The jeep ran great!
Sent using Tapatalk
The lighting in my shop could be better. Turns out I found more holes to weld along with a crack in the driver’s side fender
Continued with the plastic skim coat and sand.
Block sand the interior and exterior.
Moved the jeep out to vacuum and blow off the dust.
Removed the lights from the grill
Just after midnight I cleaned up the shop.
I also helped install a 2” lift in a 2012 JK. Coil springs, shocks, bump stops, and extended brake line brackets for the rear.
