Replaced the turn signal switch, works like a charm now.
Next thing to do is fix those headlight adjuster screws. I also rigged them up due to being brittle and old. Thanks for the info, JeeperChris.
Almost forgot to ask you, does one kit do both headlamps? There are two adjusting screws per headlamp, as we know.
I noticed that you managed to hit that stake with both the front & rear tires... then noticed that you appear to be missing?!
LMAO someone had to get the footage
I missed the snake -
Then worked on the pilot bushing with a slide hammer for a good 1/2hour.
This may sound really dumb, but I've used it multiple times now on multiple pilot bushing removals...
Take regular sliced bread. Remove crust. Stuff said bread into the pilot bushing hole - really pack it in there. Find a socket the right size to fit pretty smugly in the pilot bushing hole and tap with hammer on the bread.
Same idea as the old grease pack pressure trick, but much easier to clean up. Only out part of a sandwich. Swear it works so much easier I don't even attempt slide hammer anymore.
The kit comes with two plastic nuts as it's typically just the top adjusters that go bad. Who really adjusts the side to side movement??
Here's the link:https://www.morris4x4center.com/mts-headlight-adjuster-kit.html
You have to drill out the rivet holding the old one in which is the center rivet of the three you will see when you remove the headlight.
Dug through my junk bucket and found a 3/4” wrapped some electrical tape filled the crank bore with grease and it popped out with a few wacks.
My method is to use a 3/4" tap. While I'm turning the tap it's pulling out the bushing. I can have it out in 30-45 seconds, and no mess to clean up. You could easily use a course screw as well.
Rent or buy the tool is an option as well. Although not as fast as using a tap.
https://www.autozone.com/loan-a-too...ch-pilot-bearing-puller-attachment/230517_0_0
Got the T-4 back together this afternoon with new input shaft bearing. Still has some lateral play in the shaft but no endplay- might need it to get everything back together.
Tomorrow the Dana 300 goes back together and I have every helicoil kit except a 3/8-16 to fix the bellhousing starter bolt hole.
Made mine almost undriveable yesterday...
I have been noticing lately the throttle hasn’t been backing off at idle without blipping the gas - in checking the throttle return spring, it had relaxed a good bit, so I shortened the ends a bit and rebent the hooks. That was after work and I didn’t drive it this morning to go to work. Not only does the throttle back off now, but my right leg is gonna be bigger than my lady shortly. It COMPLETELY changed the whole gas / clutch dynamic to the point I almost couldn’t drive it LOL. I laughed all the way to work..... I’ll be hittin up the hardware store this weekend for sure
Mmmmmmm, beards
LMAO
I’ll hafta look into that. The only thing wonky right now is the stupid return spring, but much more of this and I’ll be walking in circles [emoji15]. That’ll give me something to do tonorrow
Mmmmmmm, beards
LMAO
Good luck with it.
I had similar issues. Eventually it lead to riding the brake until the throttle finally released. Not fun or safe. Also was not very responsive on the get up and go.
Replaced my springs with two different springs trying to improve the situation.
Then I got sick of it and replaces the whole setup with a hot rod kit and WOW what a difference. Woke it right up. Responsive!
If you do let a new cable I found the 36" fits best.24" is too short.
Sent from my Pixel 2 using Tapatalk
Well, I'm off until the 6th of January sooo I managed to get the right rear brakes put back together after putting the axles back in, I bolted up the retainer flanges on the both sides so now I can put the diff. cover back on. I put the tires and wheels back on too so I can roll it around. Didn't fix anything but I know what I need to replace now. Everything. Until I've the cash to fix it all, I'll just drive it around town and work the rest of the bugs out of her.
I started laying out the clearance cut on the driver's side so my adjustable seat mounts will work but I'm a bit hesitant to make the cuts yet until I quadruple check the lay out. Lol!
I welded some straps in on the driver's side seat bracket for the adjustable seat mounts I bought but I'm gonna have trouble mounting the seats now. I put the straps under the seat bracket and where I need the holes for the sliders is right on the welds on one side. Which reminds me of an old saying, measure twice, weld once. : ( I think I'm gonna have to cut them back out and put them on top or I'll just bolt them in with some counter-sunk bolts.
Started to reassemble all the fuel tank stuff, hoses, sending unit and plan on putting some speed nuts in the holes on the rear corners and center tab on the front of the tank so it won't be so hard to pull it next time. And I'm sure there'll be a next time.
Tomorrow, I'll pull the manifolds off the engine 'cuz I broke an exhaust stud off when I pulled the exhaust. Then I'll weld up the cracks in the exhaust manifold. Don't worry, I know how to do that. I think. :O
Once I get the manifolds back on, the tank back in and a battery in it, I'll fire it up to make sure I've got the fuel system working properly then I can start putting the body parts back on.
I've got a new windshield too so I'll clean up the frame and put that in as well.
Wish me luck!
I got to walk to the nearest advance auto parts twice last night bought a punch set full metric/SAE wrench set, brake fluid, and believe it or not the correct 1992 clutch master cylinder which was in stock.... what’s the odds of that???
It took me three hours to get home from work last night but I made it....... hopefully my wife doesn’t divorce me lol
Sorry to gear about your long commute. And that is shocking that they had the master cylinder in stock.
