Lmao, was way easier using the winch while holding a beer
Ground looks flat. Pull the winch completely out winch in repeat
Yeah great idea. Just hook it up to every other neighbors mailbox as you work your way down the street. :punk:
Those transformers look sturdy
Lmao I’m sure they are but I play with 480 for a living I’m all set leaving the power station alone
Lol ya there’s a 30 foot drop off to a swampy area right behind the Jeep
Meh it's only 30' that's nothing for a CJ. As for the 480 I play with it at work as well
Took it out, played in the mud managed to shatter both side marker bulb assemblies. Didn't get stuck thanks to the True Trac diffs and Maxxis RZR tires. Big fun! Only 45 mins pressure washing the muck off.
Lol you go to a car wash?
Replaced my thermostat and changed the oil. Trying to diagnose a wierd rumble as well. I did figure out its not either driveshaft. Next step is get all the tires rebalanced
Sent from my SM-A528B using Tapatalk
Best part of driving around with the glass down is watching all the newer Jeep drivers wondering how you did that LOL
They made that easier with the 20+ models the frame stays in place and just the glass folds down with a few clips
What a difference, to bad most springs seem to be junk these days, seems like all the metal quality is way down from what it used to be
Just an FYI - I bought new RC 4” springs, and the new rear ones were flat in the center just like that without ever having touched the Jeep.
Sent from my walker using Tapatalk
Finally got the rest of my parts yesterday. Going to bed blast all my brackets and pulleys today then start my engine swap. Also doing all new stainless steel brake lines and brakes and a few others as well
I did wonder about the flattened area, but mine were also quite extended. The rear of the Jeep sat about 1/2" lower than the front and the rear shackles were extended back and would hit the cross member when going over modest bumps. The new ones, while not as arched and required the extended shackles, got me level again and not bottoming out over speed bumps. So definitely worn and lost their "spring".
$100.00
  50.0%
