No, but tje rear end rusted by the tailgate hinge mounts so I have to cut out the rot and replace the entire rear crossmember. While I am at it I am also going to put in new aluminum brake lines
Sent from my SM-A528B using Tapatalk
Don't try to make aluminum brake lines. The tubing is usually seamed, the flares won't be double flares because you can't do the reverse bend as the flare splits and they are just not safe.
There are some who have used copper coated lines and there is a special new aluminum that is being developed but it requires some very specialized equipment.
IIRC, I know it's not approved for state side use and I'm pretty sure it is not Germany approved either.
Just get a set of stainless steel from inline tube the complete set pre made and ready for installation is only 170.00
Another strong brake line comes from Crown Performance. A stainless steel five layer brake line customizable if needed,
:agree:
I agree, I like CP, but that's the flex lines - not the hard lines.
Very true. I wasn't thinking about the hard lines. Hard lines may indeed be a bugger to round up.
Here's the one I used (I have an 85) they have them for narrow track as well
I splurged and got a new proportioning valve as well and master cylinder and booster so it's 100% new from pedal to rotor.
Pretty area. What was the temperature differences ?
Temperature difference? Not quite sure, but I’d say 10 degrees cooler. It’s about 9,250 feet where we were, compared to 6,650 at the house.
Looks clean from the pic
That sounds good and is a candidate for your own build thread... :chug:
There really aren't any "build" plans other than to get it fully functional. The steering needs the most attention. It already has the 11" Bendix brakes on it which appear to work fine and the 225 runs great. Way more usable poop than the damn anemic 3.6 had in the JK I sent off to be someone else's problem a month back. In the real world, it should receive a NT Dana 30 and a Saginaw box but I'm not sure I want to head down that road with this one----yet.
One sort of built Jeep (the 3B) is probably enough.
I just pulled a 52 or 53 m38a1 into the garage for some work. I'll post a few pics when I get the chance.
That’s a nice one !
Stay tuned for more pics later today
